Help re component output
Discussion in 'Plasma TVs Forum' started by stormjai, Jan 29, 2004.
  1. stormjai
    stormjai
    Nov 15, 2003
    331
    Bromley
    +3
    i have basic HC set up. Sony 730 DVD player attached via IXOS RGB scart to Pioneer plasma 434 media box, plus sound via sony AV reciever. Will change to decent component cable & progresive scan improve DVD playback? or will I need to save for external processing eg iScan. Also need use for sky+
    Thanks for any advice.
  2. jmack
    jmack
    i would not call pioneer 434 basic:D :D :D
    if your dvd player can output progressive scan then it should be better than rgb scart.
  3. daveb975
    daveb975
    Oct 25, 2002
    4,346
    103
    London
    +371
    Prog scan should make a big difference, and your 730 can output it already.
    I suggest buying a component cable and checking it out!
