Help re component 7 panasonic
Discussion in 'TVs' started by tolmie, Jul 29, 2005.
Tags:
  1. tolmie
    tolmie
    Dec 10, 2004
    1,012
    Glasgow
    +57
    Hi everyone, iv been wondering about this prob for a while, i Have a panasonic crt 32pd50, it has a component connection on the TV, I dont have a home cinema, so if I attach a component connection to my Pioneer 575 how do I get sound.
  2. JayCee
    JayCee
    Jan 20, 2004
    20,342
    Lanarkshire
    +1,954
    I'm presuming a Pioneer 575 is a DVD player?
    If so, it will probably have audio outputs..........maybe right/left phono sockets?..........get a scart to 3 phonos lead........they are usually available with a in/out switch on the scart plug end and use the red and white phono plugs which carry audio, just leave the yellow (composite video) hanging free.
  3. billystevo
    billystevo
    Mar 13, 2005
    53
    9
    Connect the component cable to DVD , enter menu and select component connection as the dvd source. Connect a scart lead between TV and DVD this will carry the sound.
