Help re: analogue/d-pad usage for a recent PS3 convert
Discussion in 'Playstation Forums' started by DrPhil, Jan 15, 2008.
  1. DrPhil
    DrPhil
    Jul 19, 2006
    24,394
    Ireland
    +10,294
    Traded my 360 yesterday for a PS3.
    So far I have only got a chance to play a few games of FIFA. The controller was one of my favourite things about the 360 and the PS3 one is hard to get used to.
    Bearing in mind that the left analogue stick and d-pad are in opposite positions on these pads, is there anyway that you can change settings etc to use the d-pad instead of the analogue? It is really hard to play FIFA and get used to stretching your thumb the extra distance. I keep either trying to use the d-pad by mistake and fiddling my tactics, or in the middle of a mazy run, my thumb slips off the analogue stick because I'm stretching too far, and because the top of the stick slopes away from the middle rather than being crater shaped like the 360 one.
