Help!! Ram Player dilemma
Discussion in 'Blu-ray & DVD Players & Recorders' started by robin1941, Nov 29, 2004.
  1. robin1941
    robin1941
    Nov 28, 2004
    11
    Hi all
    Other than Panasonic is there any other Ram players on the market ?
    I have the Panny E55 but i want another player to take in my caravan which would be cheap and cheerful.
    I've heard good reports from some of the cheapies I.e Star Logic multi region 2.1 and Pacific 1002 which people say will play anything you can put in them only nobody mentions dvd-ram discs being tested.Would appreciate if someone can recommend something.
    Many Thanks.
  2. bowler
    bowler
    Jun 8, 2003
    223
    My cheapo dvd players have problems with dvdr discs recorded on an e50.
    Get a panny dvd player that can play ram discs, its worth the extra cash.
  3. robin1941
    robin1941
    Nov 28, 2004
    11
    Just seen the Panny S27 EBS for £55.00 so i'm going to have that, saves a lot of bother but thanks all the same.
