Hi All
Looking to buy a decent home cinema setup which will mainly be used for movies and sports.
There are existing 6" in ceiling speakers which I think are pretty basic, and the centre channel is oddly not where it should be, think 2-1-2 formation rather than 3-2 as it should be.
My budget for everything is between 2-4k but I really don't need top of the range equipment, nor do I want budget/entry-level.
Here is what I have got back in terms of quotes from both providers:
Seven Oaks
REL T5 subwoofer (do I really need one)
Sony VPL-HW40ES HD 3D Projector
Sony 1050 AV Receiver
As an aside, they also suggested changing the in-ceiling speakers to B&W CCM382 but I think that may tip the budget...
Richer Sounds
Optoma HD50
Yamaha RXV677 AV Receiver
From what I've read, the SevenOaks offering sounds better but is quite a bit more expensive.
I'm not too sure on where I should be focusing my budget here as there is picture quality and sound to consider.
Any advice from you guys on product choices etc.
Seven Oaks
Richer Sounds
Optoma HD50
