Help!! quick question re recording to hdd/dvd recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by booktrunk, Jun 30, 2005.
  1. booktrunk
    booktrunk
    Feb 6, 2004
    602
    Leicestershire
    +3
    Hello,
    I use a Tivo and a computer to edit out adverts. I've got rid of my computer, but I was wondering how to get rid of adverts. I know i could just get a normal dvd-recorder and pause the recorder whilst adverts are on but that seems a pain. So if I get one with a HDD can you actually edit the program on the HDD to delete sections ie the adverts so when I record it. I have it without adverts.
    Steph
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    Yes, you can do that with any decent HDD/DVD recorder. Very quick and easy to do.
    Mark
  3. booktrunk
    booktrunk
    Feb 6, 2004
    602
    Leicestershire
    +3
    I guess the panasonic with 400gig hd at £599 from Richer Sounds is worth a lot of consideration considering the size of the harddisk in it.
    Any ideas on any others that are worth considering. I really wanted to only pay £200 but can't find one with a hdd for that.
    Steph
  4. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    I recommend this link to help you decide (as well as browsing this forum).
    http://www.btinternet.com/~james_lancaster/whichdvd.HTML
    You can get a Panasonic EH50 (80 GB HDD), or a Toshiba XS34 (160 GB HDD) for under £300. Unless you really time shift a lot, or are away for prolonged periods, a 160 GB (or even 80 GB) may be enough. 80 GB gives you ~36 hours at SP mode; ~18 hours at highest quality mode.
    Mark
  5. booktrunk
    booktrunk
    Feb 6, 2004
    602
    Leicestershire
    +3
    Thanks,
    Interesting read.
