Help! Question about Marantz 6007 with Marantz AV7007
ener1
I have just installed above AV receiver with a 6007 Marantz BD player. I can only select Multi CH IN on the receiver when i play a BD! In other words do not see DTS or whatever...just MULTI CH in on the display of the 7007... I am sure it is a setting but can't figure out what to change. ANy help appreciated
Ener1
Rick84
Is the blu ray player set to LPCM or bitstream? If set to LPCM then MULTI CH is shown on the AVR display. Thats the case with my Marantz SR7005.
ener1
Thanks Rick.
I found it! It is only accessible when you actually play a blu ray disk. It is a mode button which allows you to switch from audio output. You can then select either HD audio output or Mix audio output. I selected HD audio output and now the SR7007 indicates the correct sound output and PCM has disappeared.
Ener1
