help pw6
Discussion in 'Plasma TVs' started by bart750, Mar 19, 2005.
  1. bart750
    bart750
    Jul 1, 2004
    235
    barnsley
    hi guys
    just wanting to know what signal is getting to my pannypw6
    ihave a denon progresive dvd component out and sky + out via svideo into a yamaha upscale amp outputting component to to 15 pin vga standard board that came with the pw6 what picture will i be getting ie progresive? component? or what any help much appreciated
    thanks bart
  2. c4lln
    c4lln
    will it not just be a standard feed, because you are using a s video lead and not component cables?
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    it will be 576i from Sky via AMP (dont worry plasma will de-interlace the signal) only point in a prog scan source is if it better than the PLasma!
  4. bart750
    bart750
    Jul 1, 2004
    235
    barnsley
    thanks horney
    so the sky will be 576i
    not sure what you mean with the dvd?
    i have denon outputting component progresive into yamaha upscale amp to my pw6 via component lead to vga on the tv ?
    sorry if it sound a bit daft but i dont know what im getting into the plasma ?
    am i better off turning progresive off ?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Probably better turning progressive off on DVD but have a play let your eyes decide...dvd for pal will be 576i/p
    (assume you mean UPCONVERTING Amp ie does S-video to component...this is not the same as upscaling which is 576>720 etc)
  6. bart750
    bart750
    Jul 1, 2004
    235
    barnsley
    yes up converting is what it does ill have a play with it in dvd mode thanks for the advice
