Help purchasing DVD player
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dodgy Bob, Aug 12, 2001.
  1. Dodgy Bob
    Dodgy Bob
    Hi all,
    I'm new to all this DVD malarky but this seems quite a helpful place. I've been looking on the web at all the available DVD Players and admit to being totally lost!
    I'm after a player that has the following specs :
    built-in DD decoder<br /> 5.1 channel output<br /> CDR/CDRW compatible<br /> Multi-region<br /> Optical digital output
    Obviously excellent sound and picture quality!
    The one I've had my eye on is the Sony DVPNS400D (£249 from <a href="http://www.unbeatable.co.uk/)," target="_blank">http://www.unbeatable.co.uk/),</a> unfortunately it's not multiregion (which is a must).
    Can anyone tell me if it can be hacked or recommend a better player?
    Thanks for your time.
  2. Dino
    Dino
    Oct 9, 2000
    9
    uk
    Try Samsung sv-dvd1E DVD & Video Combo from <br /><a href="http://www.trident.co.uk" target="_blank">www.trident.co.uk</a>
  3. hobbes
    hobbes
    Try out these guys - Electrocentre, its modified to handle all regions. Delivery is £10, which still beats unbeatable.
    <a href="http://www3.netspin.co.uk/electrocentre/products.asp?ID=28" target="_blank">Sony DVPNS400D</a>
    Scroll down and you'll find it.
  4. hobbes
    hobbes
    Although for a few pennies more you can get the most excellent Sony 735 at £349. A post before dissed it when compared to the 7700 but its £200 cheaper, and it has most of the features you want.
    Tell me what the 400 is like anyway, if you get it. I'm also interested in one.
