First time post long time reader.....
I've recently purchased 42PW7 Plasma and pana tuner board + component board from AV sales (Great Guys) however Ive had a few problems setting it up.
Sky --> Tivo ----> Scart RGB to Pana Tuner board (Works Fine) AV1
PS2 ----> Scart RGB to Pana Tuner Board AV4 (works but I dont get RGB just normal) and I have got the RGB scart for the PS2
Pioneer DVD 575a Component (Y, Pb, Pr) to Component board in PW7. Works but I dont get any sound. If I run it through the tuner hey presto works fine.
Questions ?
Why dont I pick up any sound through the TV when using the Pioneer DVD 575a Component (Y, Pb, Pr) to component board in PW7 ?
Why cant I get RGB to work through PS2 ? Ive set it up through the initial PS2 screen ?
Would you guys recommend anything else I should consider with my current setup to improve the picture?
And finally do I go with buying the Pana Speakers for £200 or would you guys recommend anything else. Dont really want to go for the amp/5.1 speaker thing just left and right should do fine. They must look good on the wall though and be good quality?
Many thanks for any help !!!
Questions ?
