L
Leigh22
I have just purchased a Sony KDL40W2000 and a Sony DAVDZ630 home cinema system. This is also connected to SKY+. I have ordered a QED Qunex HDMI-SR cable to run from the TV to the DVD player. I have a scart lead running from the TV to the SKY+ box as well as a coaxial cable and a scart running from the TV to the DVD player. This has got everythin working correctly.
My problem is the picture quality on the TV. There is an outline around objects when the TV is on and the background seems out of focus. I have looked on the forum at other posts about TV settings and these have not helped. The picture quality against how it is in the shops is poor. I have changed one of the scarts to a QED one and I have a QED qunex HDMI-P lead running from the DVD player to the TV (which I have borrowed) but I haven't seen much difference. Someone suggested that if the scart leads are crossed they could cause interference with one another (changing this hasn't helped) and that scart leads are the worst ones to use. I know nothing about this so wouldn't know what to change them to. I have considered getting SKY HD but feel that the TV picture should be better than it is without it and I am very frustrated at the picture quality (or lack of it) after spending the money that I have.
Can anyone help with what type of cables I should be using to connect everything up?
Many Thanks
Many Thanks
