HELP: Projector suddenly very bright
Discussion in 'Projectors, Screens & Video Processors' started by CraigieCraigie, Aug 2, 2004.
  1. CraigieCraigie
    CraigieCraigie
    :lease: :lease: :lease:
    I'm stuck in South Africa without any Sony help:
    My Sony VPL CS6 has been a great home theatre projector for 350 hours now. Suddenly, is has lost contrast or something - bright images too bright and picture seems burned out.
    - It can't be the lamp - 350hrs on it
    - It's not the input signal, I've tried various sources
    - It's not the screen nor room, they're perfect for home theatre
    - I've fiddles all the available settings to no avail
    I'm desperate for guidance.
  2. Mirablo
    Mirablo
    Jan 16, 2003
    70
    "- It can't be the lamp - 350hrs on it"
    wouldnt be the first lamp problem under 350 hours probably not the last either. Im not saying it is .. but i wouldnt rule it out. :(
  3. danjos
    danjos
    Feb 23, 2004
    211
    normal everyday 'lightbulbs' often glow extremely bright for a while before they expire completely.
    Just a thought. not a very cheery one though :rolleyes:
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,462
    Somewhere in South Yorkshire
    +5,897
    To determine whether or not it IS the lamp
    Is the colour of maximum white brighter than it used to be?
    If yes, it pretty much has to be the lamp (unless you had some very odd contrast or brightness settings)
    If no, then the lamp is an unlikely culprit, and something must presumably have gone awry with the video processing and/or LCD drivers.
