Help! Prog Scan DVD...
Discussion in 'Projectors, Screens & Video Processors' started by ChrisN, Nov 25, 2003.
  1. ChrisN
    ChrisN
    Oct 21, 2003
    524
    +12
    I am thinking of getting a prog scan DVD player for my new plasma
    Please excuse if this is a stupid question but the DVD player will need to connect via my Yamaha AX2 amp (PS2 also) which has component.
    Does the amp have to take a prog scan signal as well, ie need to be progressive scan compatible or does the signal pass straight through???
    If the answer is yes I'm b*ggered as cannot stretch to a new amp at the mo :(
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Prog scan uses more bandwidth than interlaced but it should be fine dont have that amp or PS display
