HELP! Problems with Tosh RPTV
Discussion in 'General TV Discussions Forum' started by RobC, Jul 15, 2004.
  1. RobC
    RobC
    Jul 15, 2004
    79
    +9
    Newbie here and my first question for the forum is a plea for help :(
    I own a Tosh 40WH08B which after a very rocky start when I bought it 3.5 years ago (had 2 replacement sets after they kept blowing up) it has been faultless. Until yesterday when a mate mentioned in passing that I haven't had any problems with the telly....then bang....a problem appears. I am not to hot on the lingo but it look like the red gun has lost its convergence. I had a fiddle in the serivce menu and it came back ok for a while. But when I turned it back on the problem was back. I have attached a picture of the problem, does anyone know what the issue is? I am gonna take the back off later and give it a good clean out etc but I suspect it is something more than that.
    Any help would be fantastic!
    Rob
  2. Lizzard
    Lizzard
    Convergence board.
  3. RobC
    RobC
    Jul 15, 2004
    79
    +9
    Does this need to be installed professionally? or can a compentant electicial engineer do it? can I buy the board?
    Sorry for so many questions :)
