Help!!! - Problems with Sony 735
Discussion in 'Blu-ray & DVD Players & Recorders' started by Chandler, Apr 2, 2001.
  1. Chandler
    Chandler
    I boguht a Sony 735 in Oct/Nov and it has been working fine (apart from long dual layer changes due to single lens) but last night finished watching Wonder Boys and went to put in another film and the palyer came up with an error message saying that the disc was dirty. I took out the disc and cleaned it but still not joy. I tried a region 1, region 2 and cd and the player wouldn't play any saying "no disc" so in line with the instructions I left the machine turned on for 30 mins but no change. I used a lens cleaner but no joy!
    This morning I bought new dvd lens cleaner but the player wouldn't read the disc so obviously the cleaner couldn't clean the lens.
    Can anyone help me all the player does is mae a whirring noise like its trying to read the disc before coming up with a "no disc" message. Is there anything I can do apart from sending it back to manufacturer under warantee or has anyone else experienced similar probs? Is this likely to be a motor problem?
    Any help much appreciated!
  2. Sam
    Sam
    Nov 6, 2000
    329
    Surbiton
    +9
    Can't say I know what's wrong m8, but seeing as its only a few months old and its obviously knackered, I would assume it would be best to take it back to the dealer for a replacement or a repair.
    Wouldn't think they'd have any quibbles about fixing it.
  3. Chris Webster
    Chris Webster
    Copied from the Techtronics site as it concerns several Sony players - not sure if yours is covered but probably worth a try.
    "With the machine turned off on standby, press the following 3 buttons on the handset, in order: TITLE CLEAR POWER. The menu will come up on the TV. Select the appropriate button number for "auto adjust". The machine basically does it all. It asks you to select either a single layer or double layer disc (whatever your offending disc is.) Ejects the tray, asks you to put your disc in and then calibrates it. (It's over in about half a second... It then asks you to press a few more buttons, and then it's all over. "
    Don't select anything other than the Auto adjust or you may really stop it playing.
