Help!!! Problems with component between Sharp LC32G3AE and Liteon 5006
Discussion in 'LCD & LED LCD TVs' started by chilin_dude, Dec 28, 2004.
  1. chilin_dude
    chilin_dude
    Nov 4, 2004
    67
    I'm posting to see if any of you ever so clever people could help me? (Hope the flattery's working.)
    I used to have my Liteon 5006 dvd player hooked up to my LC32-G3AE using a scart cable, the quality was good. However I decided I wanted to use a component cable to improve the picture quality so I could used progressive scan (and possible Hi-def.) However once I changed my hookup (unplugged scart and hooked up using a new component cable I bought) and turned on the TV there were problems. It's kinda hard to explain so I took two high-quality pictures to try to help you to understand, click the links below to get to them (they are very big ;) )
    http://www.anime-gallore.com/Files/DSC00876.JPG
    and http://www.anime-gallore.com/Files/DSC00876.JPG
    As you can see, there is what I would describe as a black shadow type thing over some of the screen. The first picture is on the dvd homepage, so there is no-movement whatso ever. I've tried fiddling with settings for both the dvd player and TV and can't seem to find anyway to fix it. But I'm sure there's a way.
    I have enabled 'component' as the video output on my dvd player and selected 'component' as video INput on my TV.
    So :lease: help me!
    Thanks in advance.
  2. jimg
    jimg
    Jul 4, 2004
    826
    +58
    Is it not the Film Mode problem mentioned in the reviews ??? Try turning it off in Advanced mode.
  3. chilin_dude
    chilin_dude
    Nov 4, 2004
    67
    Hello,
    Thankyou very much for replying!!! I have no idea about this problem mentioned in reviews, do you have a link please? I will try to find advaced mode so I can disable it. But is this on my dvd or TV?
  4. jimg
    jimg
    Jul 4, 2004
    826
    +58
    It is on the TV and is at the bottom of the list on the AV input setup.
  5. chilin_dude
    chilin_dude
    Nov 4, 2004
    67
    Thanks, but it didn't work :(
    I found the film mode option but it was already turned off!
    Have you got a link to wher ethis problem is mentioned :thumbsup:
  6. chilin_dude
    chilin_dude
    Nov 4, 2004
    67
    Not sure whether I was looking in the right menu though, the 'film mode' was in
    audio>advanced>film mode...
    Anyone else?
  7. andya
    andya
    Oct 25, 2002
    2,391
    48
    manchester
    +26
    could be your dvd player is the problem,try another player with component and see if the same thing happens again
  8. jimg
    jimg
    Jul 4, 2004
    826
    +58
    The advanced I was talking about is on the same setup menu as brightness, contrast etc.
  9. chilin_dude
    chilin_dude
    Nov 4, 2004
    67
    I have tried 3 cables and same problem.
    Thanks, thats what I disabled.
    But still no-go.
  10. andya
    andya
    Oct 25, 2002
    2,391
    48
    manchester
    +26
    as i said it may not be the cable it could be the liteon dvd player has a problem,try another make of dvd player and if that works ok you will know it is your player
  11. chilin_dude
    chilin_dude
    Nov 4, 2004
    67
    Same problem with another dvd player so it must be a TV setting!
