Help!!! Problem with Sony STR-DB2000
Discussion in 'AV Receivers & Amplifiers' started by xaser1066, Jan 21, 2005.
Tags:
  1. xaser1066
    xaser1066
    Hi :hiya:
    I have a STR-DB2000 connected with only the component video leads to my VPL-HS50 projector. I cannot get the On Screen Display to work. I don't know what it should look like as the setup is very new and I have not tried it with anything else. By the way a Sony DVP-NS955V is suppling the component video for display - this works fine - I can see the DVD material when DVD is selected as the source on the AMP - but no OSD. I have tried pressing the On Screen button on the remote and this does nothing to the projected display, it just displays On Screen [ON] on the units display. Help.
    Cheers, Jason.
  2. Benoo
    Benoo
    i have the same problem maybe the osd will not work with component :eek:
