Help! Problem with new Toshiba 32Z17B
Discussion in 'General TV Discussions Forum' started by cxd, Feb 10, 2002.
  1. cxd
    cxd
    Help!
    Just setup my new 32Z17B and it's been fine 'til last night! Now every time you switch the set on from cold you get horizontal lines all over the picture (making it unwatchable), then after about a couple of minutes they suddenly dissapear and the set is fine.
    Subsequently, after a couple of hours viewing, if you turn the set off using the remote, then turn the set back on, the lines re-appear !! only this time they don't dissappear :( You seem to have to let the set cool down for a couple of hours by switching off from the front before you can watch it again.
    As I can't speak to my supplier (Saga Electrical) 'til Monday I wondered if anyone out there has seen this before and can offer any solutions/advice ? Should I ask for a reaplcement set ?
    Many Thanks
  2. HBK757
    HBK757
    Jan 15, 2002
    153
    16
    How long have you had this set ? If it's days then definately ask for a replacement. Just tell them you're not paying all that money for a "new repaired" tv. That's effectively a refurb.
  3. cxd
    cxd
    It was delivered Friday (8th Feb) so it's only 2 days old. Typical really, you take months choosing, now I've got all the hassle of sorting out another set! I think your right though - demand a new set - Many Thanks,
  4. HBK757
    HBK757
    Jan 15, 2002
    153
    16
    2 days old ?? Tell them you wont be accepting a repair, you want a new tv. It's as simple as that, don't let them tell you anything different. I got a new Toshiba RPTV after it went bad after 2 weeks.
