Help! Problem with Executer Mod
Discussion in 'Xbox Forums' started by Ramspeed, Sep 12, 2005.
  1. Ramspeed
    Ramspeed
    Apr 27, 2005
    532
    28
    +24
    I'm being an idiot. I had my PAL xbox modded with the executer 2.6 chip. I all I wanted to do is get access to the NTSC 480p/720p/1080i video settings. But the dashboard is just the same as it was before. What do I have to do now to get access to these video settings? I have the component cables as well...
    Thanks for any input.
  2. scumball
    scumball
    Jan 12, 2004
    6,472
    Harrow - London
    +440
    You have to run a program called Enigmah Video Switcher and change your Xbox into NTSC - the the dashboard will change once you have plugged in your component leads. Your installer has hopefully put that software on your Xbox somewhere....
