Help: pressure mark on plasma
Discussion in 'Plasma TVs Forum' started by anh_duong, May 4, 2007.
  1. anh_duong
    anh_duong
    Apr 7, 2007
    36
    I have just received an lg 50pc55 and i am very happy but there is a slight blemish that isn't visible unless there is a light reflecting from it and the screen is black. The blemish is hardly visible. Should I replace the screen? There are no problems replacing the screen.
  2. Uber Customs
    Uber Customs
    If the problem troubles you then I would replace the screen.
    What do you think of it, picture, sound, etc?
    BTW Where did you get the 50PC55 and is it actually a 1080p panel?
  3. anh_duong
    anh_duong
    Apr 7, 2007
    36
    i was thoroughly impressed with the 50pc55. i have never had a large flat panel before and the colour and picture quality was awesome. since i a novice in my experiences with flat panel displays take my advice with a pinch of salt. nevertheless i think it is excellent. i paid 1100 pounds for it which is not bad. the screen accepts 1080p but turns it into 1080i i think. so it is not native 1080p. search on google/lg website for the 42pc55 instructions to get the full manual. i tested it with my ps3 (games and blu-ray) and also computer and the display was perfect. very bright display with little ghosting/retention on very low power/contrast/brightness setting.
  4. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    it's 1366x768 so that's what it converts 1080p to.
