hi , ive bought a pre owned 60gb but ive just realized that it does not have playstation 3 wrote across the casing ? this is a present for someone so i dont want a dud
the shop (gamestation) says there are different editions etc but i cant find any evidence on the web.
hi,
i asked them how it was tested and they said they had just tested games in it.
they have offered for me to now take it back and swap it for one that has got the wording on it.......
Probably best to swap it - mine has PLAYSTATION 3 across the casing, and its not a sticker, its set in the plastic. Your one could have had a fall, and hence they swapped the casing, not making a great job of it. If its been dropped it may have internal damage which isnt affecting it yet.
thanks think you could be right, there are no indentations in the plastic to suggest there were ever any words there, not gonna take the chance, ill go swap it just to put my mind at ease.
