Help positioning arial for Freeview
Discussion in 'General TV Discussions Forum' started by SeeNoWeevil, Sep 1, 2005.
  1. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,693
    +873
    Is there any better method than shouting down from the attic to the wife when positioning an aerial for freeview? :D
    Our current signal is fairly poor, fine one day, breaking up the next. I'm positive it's just a case of positioning the aerial in the loft, at the moment it's just slung in any position that seemed to not break up.
    Aerial is a um.. 'big one' that presently isn't fixed to anything just propped up in the attic. Should I get someone to look at the reception meter when moving it?
    Any other tips or any devices I could borrow/hire to help?
    Dom
  2. nig28
    nig28
    Look at the other aerials, it should point towards the transmitter.
    Nigel
  3. JayCee
    JayCee
    Jan 20, 2004
    22,330
    Lanarkshire
    +2,327
    Get it mounted outside.........you'll get a far better signal.
  4. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Agree with JayCee, but get the wife to fix it and shout down to you! :rotfl:
    (Seriously, it's well worth getting an outside aerial professionally installed.)
