Help! Poor bass output with DSP Ax620
Discussion in 'AV Receivers & Amplifiers' started by MAxE, Jan 14, 2003.
  1. MAxE
    MAxE
    I've had a Yamaha DSP AX620 amp for around 6 mnths, and have just added an Eltax atomic Active sub to the system.
    I'm having problems setting the thing up. At present there's no Bass at all, not a flicker from the sub when connected to Pre Sub out . I have the speakers set in configured to SML ,altering LFE has no effect.
    The only time I have managed to get any response from the sub is by connecting the front L/R speakers through the Atomic. Then I can get bass out but it's very poor and the Vol needs to racked up to the Maximum even then.
    Does anyone have any idea of what's wrong with my system.
    Help, suggestions gratefully recieved.
    Yamaha DSP AX620
    Gale Front/Rear/Centre Speakers
    Eltax Atomic sub
    JVC HR-VXIEK Vid/DVD combo
    Dig Fibre Optical cable for DVD input
    Phono for Video input
  2. JimB
    JimB
    Aug 26, 2002
    65
    Devon
    Do you have the bass set to 'SWFR' ?
    (menu button, then speaker set)
  3. MAxE
    MAxE
    Yes I've tried setting the output to SWFR and BOTH but the Bass is still trash.
