Help plz, Can I transfer data from HDD of broken computer to another computer?
Discussion in 'Desktop & Laptop Computers Forum' started by ky8kenny, Jan 16, 2008.
  1. ky8kenny
    ky8kenny
    Nov 26, 2005
    75
    Essex
    Hi everyone,
    My friend has broken the power socket to his laptop and can no longer turn it on as it has ran out of battery. Is it possible to put the hard drive into an external case and plug that into another computer via usb and then access the documents?
    I wasn't sure if this would work because of the xp operating system on the HDD but wouldn't the xp just be files?
    Thanks for your help in advance,
    Ken
  2. echrada
    echrada
    Jul 8, 2006
    3,159
    103
    +314
    You should be able to do that, but if you can fit the hard drive to another computer (laptop) and boot with it you should be able to retrieve all you documents that way.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,533
    Rainham Essex
    +2,517
    Adding a HDD to an external case, even though it has an OS on it should be no problem. I do it a lot at work to recover files on dead PC's or HDD's with a damaged boot sector etc. If the PC tries to boot from the disc just leave the external case powered off until the PC has booted. You can then just access the documents as you would on any other HDD connected to the PC.
    Depending on the age of the laptop though wouldn't it be worth getting the power connector repaired? Shop around and you may get it fixed for around £50 (although approx £100 was the more common price when I was looking).
    Mark.
  4. Upholder
    Upholder
    Feb 14, 2006
    250
    Manchester
    +23
  5. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
  6. ky8kenny
    ky8kenny
    Nov 26, 2005
    75
    Essex
    Cheers for all your help guys. I've already got an external case so i'll just use that.
    Kind regards,
    Ken
  7. ky8kenny
    ky8kenny
    Nov 26, 2005
    75
    Essex
    The laptop is 4 years old, so he wants a new one anyways. But I think the power plug just needs a bit of soldering so it should be a diy job.
    Thanks again
    Ken
