Help Pls: Sony BRAVIA KLV-S26A10E pc resolution Problems
K
ktulu123
Hey,
Ibought my t.v last christmas to use as a pc monitor. Everything was grand at first i had the resolution through VGA At 1360 x 768. Then one day it wouldnt work that way and the only way i can use it now is by putting the resolution at 1024 x 768, and i have to chunks of black either side!
Everytime I try put the resolution back to 1360 x 768 the screen goes blank with "out of range" Please help this has been enoying me for ages!
My graphics card is: ATI X850XT Platinum Edition
K
ktulu123
I have tried that resolution too, but it says same thing! If I buy an HDMI - DVI cable will it work with a full resolution?
K
ktulu123
Yes the refraesh rate is 60hz. how would you do it normally, is there certain settings that you have to have on the t.v
P
PhinGW
I also have the same problem, when I first set up my Laptop it worked really well, I played a few movies and a playable demo of call of duty, all with no problems, then I tried to play Madden which started fine, then got a message "out of range" on the tele, haven't been able to get it to work since...
Can anyone help?:lease:
