Help Pls Bulldog + Linksys wag354g.
Discussion in 'Desktop & Laptop Computers Forum' started by whiteswan, Aug 4, 2005.
  1. whiteswan
    whiteswan
    Dec 9, 2002
    867
    Oldham
    +38
    Had Bulldog 8 meg installed a few days ago but connection keeps dropping.
    Ditched the free speedtouch modem and got a linksys wag354g gateway router.
    Problem is I dont know what parameters to enter into the set up of the router.
    I am a complete novice on this - can anybody help me?
    Cant get thru to Bulldog to ask them.
    Dave, Oldham.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  3. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    Would love to help, but www.linksys.com is down so I can't load a manual
    but generally if you can find the following settings
    Encapsulation should be PPoA-VCMUX
    VPI/VCI 0/38
    Username: bddsl-xxxxx@bulldogdsl.com
    Password: as per your email
    Generally nothing else need to be set. This will connect you. But do set security properly on your wireless lan first.
  4. whiteswan
    whiteswan
    Dec 9, 2002
    867
    Oldham
    +38
    I havent had an email from Bulldog.
    I have managed to sort out the router...............
    Dave, Oldham.
  5. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,864
    Londoner living in Doha, Qatar
    +139
    From the Bulldog Website
    SDSL Equipment Configuration
    Your SDSL equipment manual or user guide will explain the steps to go through in order to configure the equipment. Below are a few network parameters that will need to be configured in the SDSL equipment.
    DSL Setting SHDSL annex B (also G.SHDSL or ITU-T G.991.2)
    ATM settings: VPI = 0, VCI = 38
    AAL Type: AAL5
    Encapsulation: PPPoA with VC-mux (NOT LLC/SNAP)
    Authentication: CHAP (NOT PAP)
    Bulldog User Name: username@bulldogdsl.com
    Bulldog Password: password [case sensitive]
    End of website paste
    Direct from the Bulldog website. Linksys modems are fairly simple to setup, just pump the above values into it (in the correct places obviously) :D
    Hope it helps!
