Help pls - basic questions from a very basic bloke - TOSHIBA 30WL46
Discussion in 'LCD & LED LCD TVs' started by moontheloon, Feb 2, 2005.
  1. moontheloon
    moontheloon
    Hello
    I would very much appreciate some help to the questions below. I've decided to go for the LCD by Toshiba Model # 30WL46. The components in my "system" that I am looking to connect are as follows:
    1. Toshiba LCD 30WL46
    2. Pioneer all in 1 DVD/CD/Receiver surround sound system
    3. Sony Vaio laptop
    4. Sky + digibox
    My questions therefore are as follows:
    1. Do I connect the Sky+ box to the TOSHIBA and is the Scart connection/lead the best one to use ??
    2. Do I connect the DVD surround sound player to the TOSHIBA and is the Scart connection/lead the best one to use ??
    3. If I wanted to hook up my Sony Vaio laptop to the TOSHIBA, again where would I connect this to on the TV - in the PC connection port ??
    4. Is is possible to get a screen saver on the TOSHIBA i.e. like a fishtank screensaver you can get for your laptops ??
    5. Can anybody recommend a good all in one remote given that I have about 5 remotes at the moment ?
    Many thanks for any help - best rgds
    Nick
