help please
Discussion in 'Home Cinema Speakers' started by shoalin kid, May 10, 2003.
  1. shoalin kid
    shoalin kid
    strange question ,but does anyone know the wieght of m+k suround 55 rears .i need to know for speaker brackets . m+k own brackets are very exspensive ,£95 for fixed 1s i need 4 thats £400 ! i can get cheaper 1s but they only hold 4kg. anybody known,please help :rolleyes:
  2. shoalin kid
    shoalin kid
    come on there must be some M+K owners out there .i really need to no
  3. EvilMudge
    EvilMudge
    Calm down, calm down :D
    From the M&K website
    12lbs so about 5 kilos.
    HTH
  4. shoalin kid
    shoalin kid
    thanks mate do you think 1kg will be to much ,they are made of plastic the cheap 1s
  5. EvilMudge
    EvilMudge
    Plastic, M&K - are you mad?;)
    I'm sure given enough time I could dig up some all metal ones capable of doing justice to your Surround 55s, for about £25 a throw.
    As a place to start, try CPC and look in Audio Video - Stands and Supports - Loudspeaker Stands
  6. shoalin kid
    shoalin kid
    no not proper M+K 1s the cheapest are £95 .these are others,dont no wat make
  7. EvilMudge
    EvilMudge
    relax shaolin kid.
    What I was saying was that having spent a bloody fortune on M&Ks, sticking them on plastic stands would be a waste of money. CPC have some very good quality wall brackets, capable of up to 20Kg loads (4x what you need :D) at under a tenner for a pair. These should do the job nicely.
  8. shoalin kid
    shoalin kid
    i want some that sit flush to wall like M+K 1 any suguestions
