Help Please !!!
Discussion in 'Xbox Forums' started by Sc0ward, Jan 23, 2008.
  1. Sc0ward
    Sc0ward
    May 22, 2007
    238
    16
    Newcastle
    Right ok here is my problem, i have managed to get tversity working with some avi file and some .mp4 file but i cant get it to work on anything else including hd films\tv shows or any internet feeds.
    I have loads of random codecs and programs installed so think this maybe my problem, so i have just uninstalled everything included tversity and WMP11Is there a stap by step guide of the best way to go about setting everything up and installing all the correct codecs etc etc etc.
    Also how do i add internet feeds to Tversity libary from Youtube for example?
    This is my current PC spec below incase this effects anything
    Windows XP - Home Ed - SP2
    Pentium 4 3ghz
    2gb of ram
    running wireless connection via sky broadband hub to my Xbox360
    Any help would be fantastic !!!
    THANX !!!!
  2. Slyboy
    Slyboy
    Feb 3, 2007
    754
    Kent
    +52
