Help please
Discussion in 'Playstation Forums' started by Paddy328, Jan 2, 2007.
  1. Paddy328
    Paddy328
    Sep 6, 2006
    169
    warwickshire
    This may have been covered before but how do i connect to the network via the lan wire that came with the console?
    I plugged it into the back of both the pc and the ps3 and it cant find a connection. My pc says something about an ip add and the ps3 just says check network settings.
    Any help would be good cheers.
  2. Dave2
    Dave2
    Sep 9, 2006
    3,965
    Newcastle Upon Tyne
    +529
    assign an ip to the networkcard and then go to network setup and i think there is an option for auto which should detect everything for you.
  3. Paddy328
    Paddy328
    Sep 6, 2006
    169
    warwickshire
    Sorry. Forget to mention that im :censored: with computers. Is that on the pc or ps3? How do i do it?
  4. Dave2
    Dave2
    Sep 9, 2006
    3,965
    Newcastle Upon Tyne
    +529
    Have you tried the network setup on the ps3 first ? if not try it it could just be as simple as that. :)
    If not then we can go on and add a ip to your network card.
  5. Paddy328
    Paddy328
    Sep 6, 2006
    169
    warwickshire
    Just tried it follwing the ps3 manual. it stops telling you what to do after it says select easy in the connection settings. I go through that and it times out when it tests the connection.
    My pc says there is limited or no connectivity too. I click repair and it says, renewing your ip add. Then nothing
  6. Dave2
    Dave2
    Sep 9, 2006
    3,965
    Newcastle Upon Tyne
    +529
    that sounds like a connection problem to your internet, can you connect to internet via your computer ?
  7. Paddy328
    Paddy328
    Sep 6, 2006
    169
    warwickshire
    yeah fine. But it doesnt want to know when i connect the cable from the ps3. It says that it cant repair and that i should ask my network manager.
  8. Paddy328
    Paddy328
    Sep 6, 2006
    169
    warwickshire
    balls to it! I give up. Cant be bothered with it anymore.
  9. Dave2
    Dave2
    Sep 9, 2006
    3,965
    Newcastle Upon Tyne
    +529
    off the top of my head i cant remeber what options the ps3 gives you when you go to network setup.
    there should be 3 options, could you tell what they are.
    also if you goto your pc then to the controll panael and load up network connections. there should be 1 or 2 network cards there. The one you are using to connect your ps3 though, right click ans then properties.
    Once in there we need to goto tcp/ip properties, if there is an ip already assigned remove it , if not then we can enter one, 192.168.1.3 should do.
  10. Mickus
    Mickus
    Jul 11, 2005
    3,071
    South East Kent
    +332
    ...don't you need a CAT5 cross over cable for an ICS connection?
  11. Dave2
    Dave2
    Sep 9, 2006
    3,965
    Newcastle Upon Tyne
    +529
    I would have thought that would have been 1 ? could be the rpoblem though.
  12. Mickus
    Mickus
    Jul 11, 2005
    3,071
    South East Kent
    +332
    Not sure what type ships with the PS3 - prehaps someone who has imported one could clarify...
  13. Dave2
    Dave2
    Sep 9, 2006
    3,965
    Newcastle Upon Tyne
    +529
    I will have a look :) not really checked the cables.
  14. ani4ani
    ani4ani
    Nov 12, 2001
    2,111
    Belper, Derbyshire
    +195
    Its not a crossover cable - it wouldn't work at all if you plugged into you wouter - would it?
  15. Dave2
    Dave2
    Sep 9, 2006
    3,965
    Newcastle Upon Tyne
    +529
    If it is not a crossover it will not connect direct to your computer but should work via a router or hub.
  16. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    As is pretty much standard with most devices including the premium Xbox 360 and PS3 the network/ethernet cable is always a straight through. It is of no use when trying to connect said device to a PC and will only work with a router/switch/hub. You need to get yourself a cross over network/ethernet cable in order to connect to a PC and also setup ICS.
  17. Paddy328
    Paddy328
    Sep 6, 2006
    169
    warwickshire
    So what your saying is that plugging the cable that came with it wont work and that i will have to buy another one, if i want to go online without wireless broadband.
  18. Dave2
    Dave2
    Sep 9, 2006
    3,965
    Newcastle Upon Tyne
    +529
    you will get 1 from maplins couple of quid :)
  19. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    That's correct. The cable that comes with the console is meant to be used with routers and not a direct connection to a PC. If you want to do that you will need to get yourself a crossover ethernet/network cable. IMHO even though more expensive a router is a better option.
  20. shay0
    shay0
    Jan 9, 2005
    5,004
    God's Own County
    +489
    Surely a router would be better all round, as there would be no need to have the PC on when online with the PS3. Well worth the extra few quid :smashin:
  21. Paddy328
    Paddy328
    Sep 6, 2006
    169
    warwickshire
    how much are we talking?
  22. Mickus
    Mickus
    Jul 11, 2005
    3,071
    South East Kent
    +332
  23. Paddy328
    Paddy328
    Sep 6, 2006
    169
    warwickshire
    sweet. That means i can run a cable from my pc to my ps3, which is downstairs and down the hall. I'll need to measure it up. Cheers for the help guys.
  24. Paddy328
    Paddy328
    Sep 6, 2006
    169
    warwickshire
    I called orange before i ordered the cable and i can upgrade my broadband from 2.2 meg to 8meg wireless for 5 pound a month. So ive just done that. They say it will take about 10 days. Then i'll be able to join the network and go to the playstation store. Sweet.
