Help Please
Discussion in 'AV Receivers & Amplifiers' started by prit, May 29, 2002.
  1. prit
    prit
    May 29, 2002
    7
    Hello....
    I am a total novice to all this stuff here. A friend of mine has left me his sony amp to look after whilst he is travelling the world.So i thought i might aswell make use of it.I dont have too much room so i was thinking of buying left&righ rear speaker and connect them to the amp.Is this worth it or am i wasting my time&money?Also can someone please tell me how do i hook my Video, TV, DVD to the amp.
    Much Appreciated.....Many thanks.
  2. Jase
    Jase
    Mar 16, 2001
    9,468
    South Coast
    +892
    What sort of amp is it?? So we know whether its a Pro-Logic amp or one with Dolby Digital etc. Then we can help you with the different connections etc
    cheers
  3. prit
    prit
    May 29, 2002
    7
    Hi Jase..Its Sony STRDB1070..hope this helps
  4. Jase
    Jase
    Mar 16, 2001
    9,468
    South Coast
    +892
    Ok.
    Presumably you´ve already got the DVD etc hooked up to the tv.
    To really benefit from the amp you would need all 5 main speakers and a subwoofer.
    Just connect the dvd player to the amp via an Optical cable (Toslink to Toslink) or a Digital Coaxial cable. The back of the amp should have the different inputs clearly marked.
    Have a look here for cables
    www.chord.co.uk
    www.qed.co.uk
    www.hificables.co.uk
    Then connect the video via a pair of analogue (Phono) cables. You´ll also want the TV connected to the amp via a pair of these as well. Just connect them to the relevant inputs on the back of the amplifier.
    Once connected its a case of setting the amp up depending on what speakers you´ve actually got connected Fronts, Centre etc etc.
    You may find you will also need a cable from the amp to the TV to seen the amps Onscreen menus to help set up easier. Normally a composite video lead (phono) will do or an S-Video lead (if your TV has this input).
  5. prit
    prit
    May 29, 2002
    7
    Thanks Jase....Very Much Appreciated....
  6. Jase
    Jase
    Mar 16, 2001
    9,468
    South Coast
    +892
    No problem.:)
