Help please
Discussion in 'Music Streamers' started by pmauk, Feb 19, 2018.
  1. pmauk
    pmauk
    Feb 19, 2018
    London, United Kingdom
    Hi I am new to this forum and have been browsing the last few months.
    Currently I have Bose soundlink mini.
    Just moved to a bigger house and Im looking to upgrade main systems on the living room.
    Does not have to be portable, preferably has wifi and bluetooth. My budget is 250£ max.
    Currently looking at Play one/three, soundtouch 20, CA air 200 and libratone zipp. Also would consider active speakers + chromecast audio.
    Would prefer good quality sound but perhaps louder than my existing soundlink.
    Thanks a lot!
  2. muljao
    muljao
    Jan 24, 2017
    2,070
    116
    Ireland
    +752
    Set JBL lsr305
    Chromecast
    Trond Bluetooth receiver
    • Like Like x 2
    • Agree Agree x 1
    • List
  3. Paul7777x
    Paul7777x
    Jul 23, 2016
    3,166
    North east. U.K.
    +1,117
    You’re not at all likely to beat this for your budget. And I think you’ll be amazed by the sound quality upgrade.
  4. xmb
    xmb
    Sep 29, 2004
    1,250
    North Yorkshire
    +202
    You could also consider an Audio Pro Add-on C5 if a single box solution is preferable and the option to expand to multi-room required.
    As it is for a living room then why not consider a sound bar such as the Yamaha YAS-306. Not only will you get improved TV sound but you also get Bluetooth, WiFi, AirPlay and multi-room thrown in.
