Help Please!!!!!!!!!!
Discussion in 'LCD & LED LCD TVs' started by Mustang05GT500, May 3, 2005.
  1. Mustang05GT500
    Mustang05GT500
    I bought a 15 inch Samsung SyncMaster TFT LCD Monitor. I hook it all up and I plug it in but when I turn my PC on its just a white screen. The computer works on all other screens I have and the monitor has the same problem on all of my other pc's. How can I fix this problem?
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Is it hooked up with VGA or DVI?
    Jimmy
  3. Mustang05GT500
    Mustang05GT500
  4. VurtHed
    VurtHed
    Dec 11, 2002
    194
    +6
    Have you checked the settings on the on-screen menu? If not - check the settings are all correct. e.g. that it's set to input from VGA and not DVI, that the brightness and contrast are not at max etc. (thougn I'm not sure the screen would be all white in either case).
  5. scrapbook
    scrapbook
    Jan 12, 2002
    7,115
    +527
    I would guess that this is a refresh / resolution problem with your pc's if it is not a problem with the screen itself.
    Can you experiment on your pc with difference refresh rates etc?
  6. Mustang05GT500
    Mustang05GT500
    When I click on the menu button nothing happens wither, it is still bright white and no menu pops up.
  7. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    If you are not getting an on screen menu then send it back. It's faulty.
    Jimmy
