Help Please
Discussion in 'Projectors, Screens & Video Processors' started by Psylosybin, Jan 6, 2005.
  1. Psylosybin
    Psylosybin
    :confused: I'm new to this. I just bought a used Barco 600 DATA. I plugged it in and turned it on. The fans run, the LED's light up,the video switch on the back is on, the three convergence switches inside are on, but there is no beam comeing out of the front. No projection. Am I doing something wrong? I don't have any thing hooked up to it. I just wanted to test to see if it works. Does something have to be hooked up to it? Please Help. Thank You. :lease:
  2. arbey
    arbey
    Oct 8, 2002
    76
    do you have the little white box (remote) that hooks up in the back off the barco?
    You're D600 will not work without it.
    regards
  3. Vince M
    Vince M
    Nov 2, 2004
    479
    19
    Lagoa
    ...Also try putting an input into it..
  4. rob12770
    rob12770
    Jan 5, 2004
    854
    Edinburgh/Glasgow
    +42
    if you dont have the remote (white box on the back), try using an svideo source, you should see a picture then.
