Help please
romeosadre
Help please
I have purchased 2 Emphasys ceiling speakers and also a Medion touch screen
that I am looking to link together.
I would like to also add a PC to the mix as I want to play my music mp3's
I think I need a AV Amp as the speakers won't connect directly to the TV but the issue is that the moniter has no audio out only in and I want to use the ceiling speakers for everything.The PC I am looking to get is an Acer revo - which has a HDMI port
Help please!!
Can you recommend an amp?
Tight budget
newbie1
Hi there you are a bit stuck if you really dont have sound output....what model Medion do you have? Some look to have line out and spdif out which would work.
newbie1
yes seems to be no sound output, in which case you dont need an amplifier or the speakers...you could consider exchanging it for one that does...
