Help Please
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by mad murph, Dec 23, 2003.
  1. mad murph
    mad murph
    Nov 24, 2003
    28
    Hi everybody
    I have recently bought an JVC GR-D20 and would like to be able to download to my pc.
    The camera does not have a USB port so I cannot do it that way, I have heard people mention Firewire cards.. but am unsure if this is the right route to take.
    Any help anybody vould give me on this would be appreciated.
    John
    Merry xmas & Happy New Year to all.
  2. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    In a nutshell, Firewire is the only route to take!
    If your PC doesn't already have a Firewire port then cards are available for very little cost. With Firewire, there will be no degredation in quality at all when you download to your PC. You will then be able to edit your footage using whatever program you like. If you've got Windows XP, then Movie Maker v2.0, a free download from Microsoft's web site, is as good a place to start as any.
    I don't think that your camera has DV input, so you will not be able to save your edited footage back to tape, but if you've got a DVD burner, you can create your own DVDs, so keeping the quality. If you've only a CD burner, then you can create SVCDs, but the quality isn't that great.
    Hope this helps.
  3. mad murph
    mad murph
    Nov 24, 2003
    28
    Thanks for the reply.
    Firewire it is then, can anybody recommend a good package, I have seen Pinnacle Studio DV V8 at Dixons for 49.99 is that any good.
