Help please with Yamaha 620 remote
Discussion in 'AV Receivers & Amplifiers' started by Spencem, Oct 30, 2001.
Tags:
  1. Spencem
    Spencem
    Oct 15, 2001
    202
    Northampton
    +9
    I have just become the proud owner of a Yamaha DSP-AX620 amp, with a multi remote. Despite going though every Toshiba code in the book I cannot get it to compleatly control my 36ZP18P, several of the codes nearly work but none of them let you select the AV inputs, the one thing I need.:mad:
    Also does anyone know if it is possible to run a Grundig Sky Digital box with this remote?
    Any help would be greatfully received.
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Try this:
    http://www.yamaha.com/yec/customer/codes/RX-V620codes.pdf
    It may already be something you have. It's a .pdf document so you'll need Adobe's plug-in. I know for a fact though, that they don't all work, because I could never get the control to work my Sony Minidisc recorder. In the end I bought myself the Cambridge Audio M1 learning remote. It's no Pronto but it serves my purposes.
    Hope this helps.
  3. Andrew_arkless
    Andrew_arkless
    Sep 19, 2001
    181
    Essex
    +6
    The code for Pace Sky digital works for the Grundig digibox.
  4. Spencem
    Spencem
    Oct 15, 2001
    202
    Northampton
    +9
    Thanks guys, the Pace code works a treat, however no such luck with the tele:( I'll just have to use two remotes, hardly worth buying a Pronto for one button!
  5. mjn
    mjn
    May 24, 2001
    23,487
    Herts, England
    +11,879
    u know you need a pronto!!
