help, please, with connection types
Discussion in 'Xbox Forums' started by Sam24, Mar 12, 2006.
  1. Sam24
    Sam24
    Jan 3, 2006
    160
    +9
    hi, please could you help me by answering these 2 questions:
    1. what is the best connection type for me to connect my 360 to my HDTV?
    and 2. what is the best connection type for me to connect my 360 to my SDTV?
    thanks very much, Sam
  2. DarkEntity
    DarkEntity
    Feb 13, 2005
    2,579
    2
    137
    Glasgow
    +600
    HD use either VGA or component
    SD RGB scart i would think.
  3. Sam24
    Sam24
    Jan 3, 2006
    160
    +9
    is the component connection the one which came with my premium pack?
    and is vga or component better? or both the same quality?
    thanks
  4. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    The cable that comes with the premium is a combination component and composite cable. Which connections you use will depend on whether you have an SDTV or a HDTV. If you have an SDTV the best connection would be RGB scart which is available as a seperate option. If you don't have a HDTV but do have a PC monitor you can still get HD by using the optional VGA cable. At the end of the day what cable you use will depend on what connection options you have and what type of display you're using.
