Help please with ceiling mount height
Discussion in 'Projectors, Screens & Video Processors' started by Jim McC, Apr 22, 2004.
  1. Jim McC
    Jim McC
    Mar 28, 2004
    64
    Wisconsin
    I'm trying to decide on my first proj. but I need help with a couple questions first. My finished ceiling height is only 6'8" tall. I want to mount a 16:9 screen on wall all the way up to ceiling if possible. Do I need a proj. with lens shift to make this work? I don't want to use keystone correction. I don't want underside of proj. below 6' height. Is 8" enough height to make this work? I sure could use some advice.
  2. Quatermass
    Quatermass
    Tbh, I don't know. But having used Z2 lens shift to get a non-keystoned image myself - I can confirm that it is very effective. I would guess (and it is a guess!) that given your circumstances it would be difficult to get a non-keystoned image without lens shift.
