Hi all,
I am looking for a 50 / 55 inch screen for a Boardroom at work. The TV will only be used for Freeview TV and as a computer monitor. The room is 3.3m end to end and does have a smallish window that is directly in front of the screen although this could be fitted with a blind if necessary.
The Samsung 55D6100 has been suggested but I'm not sure about a) the suitability of LCD for the task and b) that particular model of Samsung.
I would appreciate any thoughts or suggestions you may have.
Thanks....
Thanks....
