Help! Please Sony or Pioneer
Discussion in 'AV Receivers & Amplifiers' started by playz28, Sep 23, 2005.
Tags:
  1. playz28
    playz28
    Hi all this is my first post.
    I've had a Sony CMT-HP7 system for about 3 years now and it’s served me well.
    http://www.avland.co.uk/sony/cmthp7/.
    Since having optical out on my soundcard, vie gotten tired of swapping the cable for DVD and computer depending which one I want to hear loud on the system.
    I have since brought a Pioneer VSX C300 http://www.avland.co.uk/pioneer/vsxc300/ so I don’t have to keep swapping the cables round.
    Since getting the Pioneer and setting it up. I get a little bit of hiss on my Sony speakers when connected straight to the Pioneer. Its nothing major just im picky and it definitely more noticeable than the speakers being connected to the Sony system.
    My question is should I run the speakers direct from the Pioneer or use the line out from the pioneer to feed the line in on the Sony and run the speakers of the Sony system?
    Thanks in advance
