Help please - sony MD -> PC
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Kazuya Mishima, May 14, 2004.
  1. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,429
    North East Scotland
    +65
    Does anyone know if it is possible to "download" tracks from a Sony MD (MZ-N710) which are in ATRAC format, onto my PC, and into .WAV for recording onto CD.....
    I have tried to "check-in" the tracks - as according to the Sony soundstage software - but it keeps saying transfer failed. The tracks on the MD were recorded a couple of years ago, through the analogue line in.
    Any ideas?
    Thanks.
  2. KJ_Palmer
    KJ_Palmer
    You can't do that with the current crop of NetMD units, for which downloading is a one-way process (PC->MD). Your only option is to record your tracks in real-time to WAV or whatever on your PC using an analogue lead.
    The next generation of MD (Hi-MD) will allow two-way uploading/downloading. These are due around July this year...
  3. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,429
    North East Scotland
    +65
    That's annoying as the software bundled with the MD has the option to "check-in" (i.e. load back into the PC) as well as "check-out".
    What software would I need to record into WAV format?
  4. tom_nieto
    tom_nieto
    May 21, 2003
    427
    Brighton
    About the best I can suggest is audiograbber. It's not so good at separating tracks, but it can be done if you want. It just uses analogue, although I guess it could be set to a digital input, although I don't think you can record digitally from MD to another source anyway.
    Plug your player into your computer's line in and work from there.
  5. KJ_Palmer
    KJ_Palmer
    You can (transfer digitally), but you need a deck with a digital output such as the Sony MDS-JB980.
  6. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,429
    North East Scotland
    +65
    Thanks guys for your help.
