HELP PLEASE: Sky signal problem?
Discussion in 'Sky Digital TV Forum' started by Ponty, Jul 7, 2005.
  1. Ponty
    Ponty
    Feb 15, 2005
    68
    Can someone shed some light....
    I've recently been decorating etc and have unplugged and moved the sky box (early Panasonic) about a few times.
    I'm now having problems with "no satellite signal being received", but only on BBC1 & BBC2. All other channels, including sports/movies etc work fine?
    My parents who only live 5miles up the road are having no such problems?
    Is this a fault with box or with transmission?
    Many thanks
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Probably a faulty LNB. The power to the LNB generates a little heat which helps to keep it dry. It may solve itself, but you may need a new one if it doesn't. BBC1 and BBC2 are usually the first ones to suffer if you have a bad LNB - look at the signal strengths and qualities.
  3. Bluevanman
    Bluevanman
    Also, the older boxes 'remember' that they haven't had a signal. Try a reboot and see what happens.
  4. Ponty
    Ponty
    Feb 15, 2005
    68
    Is the re-boot simply switching it off/on or is there a specific way?
  5. broxy
    broxy
    Switch off at the mains for 10 seconds then leave on standby for a further minute and then switch on.
