Syphon
Established Member
- Joined
- May 26, 2005
- Messages
- 634
- Reaction score
- 34
- Points
- 178
I've just upgraded my speakers to some Q Acoustics 2000i 5.1.
I'm looking to wall mount the rear speakers at 90 degrees, which would be fine, except the official brackets won't go to this angle.
I can mount the speakers directly on either wall however this will mean there is about 2 foot difference in distance between the seating position.
Is this a non issue and Audyssey will take care of it, and I'm being too fussy, or should I be seeking to get different brackets and mounting the same distance?
Hope that makes sense!
Cheers,
Scott
Cheers,
Scott
