Help please re connections
yarand
From previous experience I have found that connecting my Sky + box to my DVD recorder (by Scart) will produce a better Sky + picture on the TV compared to plugging the Sky + direct into the TV, due to the DVD/TV connection being via Component Video.
I now have a supplementary system with Digital TV but with only a DVD player rather than a DVD recorder. Does anybody know if I can adopt a similar methodology and route the Digital TV set-top box through the DVD player's single Scart to take advantage of the DVD player's component video connection to the TV? Or can I not do this - is the DVD player's Scart connection for output only - and hence do I have no choice other than to plug the Digital TV set-top box direct to the TV?
S
StuJe
I assume if you connect your Sky to your TV it is into an RGB capable scart connection, and you are setting the Sky to RGB not PAL.
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
