help please - problem turning off "debonce" on MCE 2004
Discussion in 'Microsoft Windows' started by newstuart, Mar 25, 2005.
  1. newstuart
    newstuart
    Apr 22, 2004
    1,797
    Northumberland
    +82
    Ive just reloaded MCE 2004 after getting swamped with viruses
    I now find my pronto remote will not work as the systems turned "debounce" back on ie only 1 key press will work.
    I went into registry edit and tried the folowing fix which worked before,
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\idIr\Remotes\745a17a0-74d3-11d0-b6fe-00a0c90f57da]
    You should see a DWORD key called "EnableDebounce". You'll notice it's set to 1. Set it to 0 to disable debouncing.
    I get as far as services but when i drill down there is no refernce to "idir"
    Is there another fix or does anyone know how i can solve it please ????? :lease:
