Help please! Problem setting up Denon with Hitachi plasma
Discussion in 'Plasma TVs' started by kismet110, Mar 26, 2005.
  1. kismet110
    kismet110
    Feb 6, 2005
    2,360
    London, UK
    +389
    I eventually got around to unpacking and setting up the Denon DHT500 with a Hitachi 42PD5200 plasma today but have run into a couple of problems, hope some kind soul can help:lease:
    I initially attached via SCART cable, attached all the speakers and went into the set up menu. I switched the output to component, turned off, disconnected the SCART, connected the component lead, l/r audio and video jack then powered it up again.
    Whilst the sound is fine the picture is not; it had a heavy green tinge when I played A Bugs Life, switched disk in case it was a one-off, still the same problem.
    I've gone back into setup, still is set to Component so not sure what is going on! Also, if I turn on Progressive Scan on the DVD the picture becomes unwatchable; "No Sync Signal" comes up on the screen - I think this 2nd problem is related to the de-interlacing done by the plasma screen itself but would be great if someone could confirm this?
    Am now going to try switching setup back to RGB and re-connecting via SCART to confirm the green tinge is a component-only problem, in the meantime your ideas/advice would be most appreciated.
    Regards
    ALI
    (cross-posted in All-in-One Forum)
  2. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    that green tinge can be the result of blue and green cables being the wrong way round
  3. kismet110
    kismet110
    Feb 6, 2005
    2,360
    London, UK
    +389
    Thanks for your prompt response mep, whilst setting it up to run via SCART again I had a thought and went into the setup on the plasma and noticed AV2 input wasn't set to component, still on composite - DOH!
    Switched this to component, tried again and voila, no greenish tinge or lack of signal when using P-Scan.
    Thanks again.
    ALI
  4. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    Doh indeed!....:)
