help please no Freeview
Discussion in 'Freeview & YouView' started by ecochild, Feb 21, 2013.
  1. ecochild
    ecochild
    Feb 21, 2013
    ok so i recently just moved into a block of modern flats and we can get free view in the living room fine on the wall behind the tv is two sockets one has tv sat dab triplexter if thats what u call it then next to it there is a socket which has the same connection as the dab ok so i have that same socket in my bedroom and i have gone out and got a new freeview box and tryed to get it to work in the bedroom but it cant find any signal surely they would alow u to watch tv in the bedroom this cant just be for dab and radio can it i need help because i like to watch tv in bed lol
  2. lbear
    lbear
    Mar 9, 2010
    2,117
    83
    +337
    Sounds like the second wall plate is to take the RF out from something like a Sky box for "multiroom" use. Have you tried connecting a lead from the TV out on the multiway plate to this one? If this is the case, the TV signal should now be going to the plate in the bedroom.
    Once you have established this is the reason for the setup, you will have to see about splitting the UHF signal. If you have a PVR and are not worried about using the tuner built into the TV, you could use the RF out on the PVR to "daisychain" the signal to the second wall plate. If not, you will have to put in a splitter of some sort. The passive "Y" shaped ones reduced the signal to less than half and whether instead you will have to get a small amp/splitter will be a matter of trial and error.
    Edit: a few TVs have a similar RF out arrangement to "daisychain" the signal. You should also find one on the back of an ordinary Freeview set top tuner box.
  3. kokolino23
    kokolino23
    Oct 18, 2009
    1,062
    Cardiff
    +47
    Did you manage to sort this out?
