alanjrobertson
I've taken the plunge and have got a Samsung LE40M87BDX LCD TV. I've also got Sky HD winging its way to me and already have an Xbox 360.
The missing bit that I'd really appreciate some help with is what to do for amp/speakers.
I've read in a couple of places about optical links between the Sky HD box and the amp/decoder - does this mean I have HDMI going to the TV and then optical going to the amp? How should I connect the Xbox?
As well as advice re. connections I was looking for some recommendations of products to go for. It's a new-build flat with laminate floor so it's a bit tricky speaker-wise.
Proposed setup is:
As you can see I can't run speaker cable down the left as its open-plan and down the right is the main door into the room I was therefore quite interested in some of these systems that have wireless rear speakers - as you can see there is a power socket behind to sofa so this would work out well from that point of view. Does anyone have any suggestions of good systems to go with?
Many thanks for any info/suggestions!
Alan
Proposed setup is:
Alan
