Help Please - My Philips Dvd Player Froze When Playing Back a Dvd-r :(
Discussion in 'Blu-ray & DVD Players & Recorders' started by CHR1S, Dec 14, 2004.
  1. CHR1S
    CHR1S
    I have recently puchased a Panny E55 DVD Recorder and recorded a film on BBC1 the other night using FR Mode (135 mins). I used a Datawrite (Fuji dye) 4x disc and finalized the disc in the recorder as the instructions say.
    When I played the disc back on my Philips 622 DVD player the audio seemed very poor and very slightly out of sync, also towards the end of the film the frame just froze up and none of the buttons would work! I had to unplug the Philips DVD player to reset it.
    Does this sound like a disc fault / player fault or Panny recorder not recording to the disc correctly fault?
    Thanks for any help in advance!
    Chris
  2. CHR1S
    CHR1S
    surely somebody must knwo :(
  3. tabatha
    tabatha
    Jun 9, 2004
    180
    16
    West Midlands, UK
    If there is a Philips involved, my first suspicion would be there! I suspect that the Philips does not like the dye very much and is having trouble reading it - finally giving up the ghost as the track gets nearer the outer edge of the disc and has greater difficulty tracking any eccentricities. You could try a better quality disc - Panasonic or Taiyo Yuden.
  4. mentsugi
    mentsugi
    Oct 2, 2002
    386
    +24
    I would agree. The problem you are seeing is due to poor quality cheap DVD-R or a type that the machine does not like.
    The test method for Panny recorders is to try to enter a disk title on the DVD-R before using it for a recording. If it enters the title then almost all recordings are completed OK.
